"id": "23f89069.d23c2",
"type": "tab",
"label": "IKEA Blinds",
"disabled": false,
"info": ""
"id": "1cf7b8db.ce10b7",
"type": "homeeDevice",
"z": "23f89069.d23c2",
"virtual-homee": "",
"name": "Rollo Schlafzimmer",
"nodeId": "2050",
"profile": "2002",
"icon": "nodeicon_shutter",
"attributes": "[{\"id\":2052,\"node_id\":2050,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":100,\"target_value\":100,\"last_value\":100,\"unit\":\"%25\",\"step_value\":1,\"editable\":1,\"type\":15,\"state\":1,\"last_changed\":1573237874,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2053,\"node_id\":2050,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":95,\"target_value\":95,\"last_value\":95,\"unit\":\"%25\",\"step_value\":1,\"editable\":0,\"type\":8,\"state\":1,\"last_changed\":1573711842,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2054,\"node_id\":2050,\"instance\":0,\"minimum\":0,\"maximum\":4,\"current_value\":1,\"target_value\":1,\"last_value\":0,\"unit\":\"n%2Fa\",\"step_value\":1,\"editable\":1,\"type\":135,\"state\":1,\"last_changed\":1573237874,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2055,\"node_id\":2050,\"instance\":0,\"minimum\":0,\"maximum\":4,\"current_value\":4,\"target_value\":4,\"last_value\":3,\"unit\":\"n%Fa\",\"step_value\":1,\"editable\":0,\"type\":33,\"state\":1,\"last_changed\":1581697259,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\"},{\"id\":2056,\"node_id\":2050,\"instance\":0,\"minimum\":0,\"maximum\":0,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"text\",\"step_value\":1,\"editable\":0,\"type\":45,\"state\":1,\"last_changed\":1573065500,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"IKEA blind by chiroptera\"}]",
"x": 770,
"y": 300,
This file has been truncated. show original
