Hello Community:bat:
I like to ask you about help with some homeegram settings.
I have got a following installation:
2x FTM 20 TF sensor
2x Qubino flush 1D relay
1x Brain cube
1x EnOcean cube
1x Z-Wave cube
Relay 1 controls radiator heating circuit (switches input in gas boiler)
Relay 2 controls underfloor heating circuit (switches input in gas boiler)
Sensor 1 (FTM 20 TF) measures temperature on the floor with radiators.
Sensor 2 (FTM 20 TF) measures temperature on the floor with underfloor heating.
I set a homeegram for the HOME frame - relay switch ON
IF Radiator circuit temperature falls under 22°C
ONLY IF time frame is MO, TU, WE, THU between 6:30 to 21:00
ONLY IF mode is HOME
THEN Radiator relay SWITCH ON
I set a homeegram for the HOME frame - relay switch OFF
IF Radiator circuit temperature rises over 23°C
THEN Radiator relay SWITCH OFF
I set a homeegram for the VACATIONS frame - relay switch ON
IF Radiator circuit temperature falls under 16°C
ONLY IF mode is VACATIONS
I set a homeegram for the VACATIONS frame - relay switch OFF
IF Radiator circuit temperature rises over 18°C
PROBLEM:
With settings above it works properly only when the mode is AT HOME and during set time frames.
After mode is changed from AT HOME to VACCATIONS it does not accept the mode change and it still works in AT HOME mode.
Example from yesterday evening: At 20:14 felt the temperature under 22°C ant the relay switched ON – that was correct. However at 21:00 set temperature (23°C) still was not reached, the relay was still switched ON. I expected that the relay will switch OFF because the condition ONLY IF time frame is MO, TU, WE, THU between 6:30 to 21:00 was not fulfilled.
I do not think that the homeegrams are set correctly according to the requirements we have.
QUESTIONS:
Day temperature 23°C is set from 6:30 to 21:00?
How to set the homeegram for setback (night) temperature from 21:00 to 6:30? -
Is it possible to set a manual homeegram/s which allow/s after one click to switch ON the radiator circuit and switch it OFF when the day temperature is reached?
Does the system reacts immediately after switching mode from AT HOME to VACCATIONS?
Could you please help me with the right homeegrams settings and explanation?
Thank you very much
Pat
