Blinking means it is booting (slow blinking) or a cube is found and set up (fast blinking). A full green light is what would be the good sign. So, is it blinking or shining in green?
I unfortunately broke the usb connector. I have another brain, but I forgot its userID and pwd. Any way to factory reset it in order to perform an brand new install… this will be the best option I guess… I am progressing and become hopeful… thanks guys
I am not there yet. I managed to upgrade the brain with a connection to my PC with the FW V1
I managed to make a reset.
I started the new install (connecting on the wifi of the device with my cell and following the steps of the app), creating a new account, but I am block because it does not see my wifi and I cannot input it. (my wifi has not changed since the last connection - SSID visible - WPA2).
Any idea why the app does not see it ? I will try again later in the day. thanks
Sometimes (especially in busy areas) it doesn’t get all wifi networks on the first scan. Unfortunately the only option to rescan is a reboot. It performs a scan on startup.
If you still are in “warranty” period (2 years in Germany, don’t know where and from whom you bought it), send it back with proof or purchase to Codeatelier
