        "id": "f62252da.8fb58",
        "type": "tab",
        "label": "Landroid",
        "disabled": false,
        "info": ""
        "id": "80cf43fd.3045a",
        "type": "homeeDevice",
        "z": "f62252da.8fb58",
        "virtual-homee": "",
        "name": "Mähroboter",
        "nodeId": "65",
        "profile": "19",
        "icon": "nodeicon_ventilationsystem",
        "attributes": "[{\"id\":650,\"node_id\":65,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"m%C3%A4hen\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":651,\"node_id\":65,\"instance\":2,\"minimum\":0,\"maximum\":1,\"current_value\":1,\"target_value\":1,\"last_value\":1,\"unit\":\"Laden\",\"step_value\":1,\"editable\":0,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":652,\"node_id\":65,\"instance\":1,\"minimum\":-100,\"maximum\":100,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"%25%20%2B\",\"step_value\":10,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":1573711842,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":653,\"node_id\":65,\"instance\":2,\"minimum\":30,\"maximum\":750,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"%27%20Regen\",\"step_value\":30,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":1573711842,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":654,\"node_id\":65,\"instance\":1,\"minimum\":0,\"maximum\":10000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"km gefahren\",\"step_value\":1,\"editable\":0,\"type\":3,\"state\":1,\"last_changed\":1572807225,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":655,\"node_id\":65,\"instance\":2,\"minimum\":0,\"maximum\":10000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"h M%C3%A4hzeit\",\"step_value\":1,\"editable\":0,\"type\":3,\"state\":1,\"last_changed\":1572807225,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":656,\"node_id\":65,\"instance\":0,\"minimum\":-10,\"maximum\":100,\"current_value\":20,\"target_value\":20,\"last_value\":20,\"unit\":\"%C2%B0C%20Akku\",\"step_value\":0.1,\"editable\":0,\"type\":5,\"state\":1,\"last_changed\":1573711842,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":657,\"node_id\":65,\"instance\":3,\"minimum\":0,\"maximum\":100000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"x%20geladen\",\"step_value\":1,\"editable\":0,\"type\":3,\"state\":1,\"last_changed\":1572807225,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":658,\"node_id\":65,\"instance\":1,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"Kante\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":660,\"node_id\":65,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":100,\"target_value\":100,\"last_value\":100,\"unit\":\"%25\",\"step_value\":1,\"editable\":0,\"type\":8,\"state\":1,\"last_changed\":1573711842,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":661,\"node_id\":65,\"instance\":0,\"minimum\":0,\"maximum\":4,\"current_value\":3,\"target_value\":3,\"last_value\":4,\"unit\":\"n%2Fa\",\"step_value\":1,\"editable\":0,\"type\":33,\"state\":1,\"last_changed\":1572634009,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"node\":\"[Circular ~.node]\"},{\"id\":662,\"node_id\":65,\"instance\":0,\"minimum\":0,\"maximum\":10000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":0.001,\"editable\":0,\"type\":45,\"state\":1,\"last_changed\":1573711842,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"}]",
        "x": 670,
        "y": 380,
  Diese Datei wurde abgeschnitten. Original zeigen
