Wenn man die Kamera schon so eingebunden hat ist man auch nur noch einen Copy&Paste Schritt davon entfernt die Kamera - und alle anderen am homee angebundenen Geräte - per Logitech Harmony Universal Fernbedienung bequem von der Couch aus zu nutzen:
Kamerakontrolle per Harmony:
- Anfahren von Preset Positionen
- Schrittweise Pan&Tilt Steuerung
- Aktivieren/Deaktivieren des Alarms wenn man zuhause angekommen ist, bzw. das Haus verläßt.
- Kurze Videoaufnahme auf Knopfdruck
- Manuelle Alarmauslösung zum starten aller aktiven Alarmaktionen
[{"id":"b26a205b.d0677","type":"fakeroku-device","z":"a5076ea7.7ad67","confignode":"2be0b813.29d1b8","x":80,"y":40,"wires":[["2b046956.4d3cb6","be58af7.98cd35","a9d93e53.614c8","a62be554.ee3458","3f0b1d37.2f7372"]]},{"id":"2b046956.4d3cb6","type":"switch","z":"a5076ea7.7ad67","name":"PTZ","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Up","vt":"str"},{"t":"eq","v":"Down","vt":"str"},{"t":"eq","v":"Left","vt":"str"},{"t":"eq","v":"Right","vt":"str"},{"t":"eq","v":"Select","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":286,"y":192,"wires":[["ad535231.93481"],["cb334ab7.b51a18"],["47db2c92.f34a84"],["5a6de1ad.b115f"],["e6ddab7a.b5b568"]]},{"id":"9ef72c0f.935c4","type":"mqtt out","z":"a5076ea7.7ad67","name":"features/ptz/movestep","topic":"instar/local/features/ptz/movestep/raw","qos":"1","retain":"","broker":"ac792e24.b9ef3","x":627,"y":192,"wires":[]},{"id":"ad535231.93481","type":"change","z":"a5076ea7.7ad67","name":"up","rules":[{"t":"set","p":"payload","pt":"msg","to":"up","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":112,"wires":[["9ef72c0f.935c4"]]},{"id":"cb334ab7.b51a18","type":"change","z":"a5076ea7.7ad67","name":"down","rules":[{"t":"set","p":"payload","pt":"msg","to":"down","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":152,"wires":[["9ef72c0f.935c4"]]},{"id":"47db2c92.f34a84","type":"change","z":"a5076ea7.7ad67","name":"left","rules":[{"t":"set","p":"payload","pt":"msg","to":"left","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":192,"wires":[["9ef72c0f.935c4"]]},{"id":"5a6de1ad.b115f","type":"change","z":"a5076ea7.7ad67","name":"right","rules":[{"t":"set","p":"payload","pt":"msg","to":"right","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":232,"wires":[["9ef72c0f.935c4"]]},{"id":"3df01041.4fb75","type":"inject","z":"a5076ea7.7ad67","name":"Activate","topic":"","payload":"","payloadType":"num","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":605,"y":91,"wires":[["d976997d.fd4008"]]},{"id":"d976997d.fd4008","type":"change","z":"a5076ea7.7ad67","name":"Initialize","rules":[{"t":"set","p":"counter","pt":"flow","to":"-1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":745,"y":91,"wires":[[]]},{"id":"a9c1729a.e5523","type":"function","z":"a5076ea7.7ad67","name":"Counter","func":"var status = msg.payload;\n\nvar counter = flow.get(\"counter\") || 0;\n\nif (status == \"Fwd\")\n {\n \n if (counter < 3)\n {\n counter = counter + 1;\n flow.set(\"counter\",counter);\n return msg;\n }\n else\n {\n counter = 0;\n flow.set(\"counter\",counter);\n return msg;\n \n }\n }\n \nelse {\n \n if (counter > 0)\n {\n counter = counter - 1;\n flow.set(\"counter\",counter);\n return msg;\n }\n else\n {\n counter = 3;\n flow.set(\"counter\",counter);\n return msg;\n }\n}\n\n ","outputs":1,"noerr":0,"x":412,"y":42,"wires":[["fad6fb17.77e6f8"]]},{"id":"be58af7.98cd35","type":"switch","z":"a5076ea7.7ad67","name":"FWD/REV","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Fwd","vt":"str"},{"t":"eq","v":"Rev","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":272,"y":40,"wires":[["a9c1729a.e5523"],["a9c1729a.e5523"]]},{"id":"7a8a17b1.e2f378","type":"mqtt out","z":"a5076ea7.7ad67","name":"features/ptz/preset","topic":"instar/local/features/ptz/preset/raw","qos":"1","retain":"","broker":"ac792e24.b9ef3","x":718,"y":42,"wires":[]},{"id":"fad6fb17.77e6f8","type":"function","z":"a5076ea7.7ad67","name":"Position","func":"msg.payload = flow.get(\"counter\") || 0;\n\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":42,"wires":[["7a8a17b1.e2f378"]]},{"id":"a9d93e53.614c8","type":"switch","z":"a5076ea7.7ad67","name":"Home/Back","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Home","vt":"str"},{"t":"eq","v":"Back","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":277,"y":338,"wires":[["f3e9fd41.d8395"],["fabc1f41.1f26c"]]},{"id":"f3e9fd41.d8395","type":"change","z":"a5076ea7.7ad67","name":"1","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":416,"y":320,"wires":[["355ce377.fcf90c","49822082.660a","90548647.456b88","b7f8bedc.a4f0e","393d303d.e8f98"]]},{"id":"fabc1f41.1f26c","type":"change","z":"a5076ea7.7ad67","name":"0","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":416,"y":360,"wires":[["393d303d.e8f98","b7f8bedc.a4f0e","90548647.456b88","49822082.660a","355ce377.fcf90c"]]},{"id":"49822082.660a","type":"mqtt out","z":"a5076ea7.7ad67","name":"alarm/area1/enable","topic":"instar/local/alarm/area1/enable/raw","qos":"","retain":"","broker":"ac792e24.b9ef3","x":632,"y":307,"wires":[]},{"id":"90548647.456b88","type":"mqtt out","z":"a5076ea7.7ad67","name":"alarm/area2/enable","topic":"instar/local/alarm/area2/enable/raw","qos":"","retain":"","broker":"ac792e24.b9ef3","x":632,"y":353,"wires":[]},{"id":"b7f8bedc.a4f0e","type":"mqtt out","z":"a5076ea7.7ad67","name":"alarm/area3/enable","topic":"instar/local/alarm/area3/enable/raw","qos":"","retain":"","broker":"ac792e24.b9ef3","x":632,"y":399,"wires":[]},{"id":"393d303d.e8f98","type":"mqtt out","z":"a5076ea7.7ad67","name":"alarm/area4/enable","topic":"instar/local/alarm/area4/enable/raw","qos":"","retain":"","broker":"ac792e24.b9ef3","x":632,"y":445,"wires":[]},{"id":"355ce377.fcf90c","type":"mqtt out","z":"a5076ea7.7ad67","name":"features/ptz/preset","topic":"instar/local/features/ptz/preset/raw","qos":"1","retain":"","broker":"ac792e24.b9ef3","x":633,"y":260,"wires":[]},{"id":"a62be554.ee3458","type":"switch","z":"a5076ea7.7ad67","name":"Play","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Play","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":253,"y":504,"wires":[["d70cf264.cb336","c84b3ab8.9b43a8"]]},{"id":"437645a0.be9ddc","type":"mqtt out","z":"a5076ea7.7ad67","name":"features/manualrec/start","topic":"instar/local/features/manualrec/start/raw","qos":"1","retain":"","broker":"ac792e24.b9ef3","x":612,"y":504,"wires":[]},{"id":"d70cf264.cb336","type":"change","z":"a5076ea7.7ad67","name":"{\"val\":\"60\"}","rules":[{"t":"set","p":"payload","pt":"msg","to":"60","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":412,"y":504,"wires":[["437645a0.be9ddc"]]},{"id":"c84b3ab8.9b43a8","type":"delay","z":"a5076ea7.7ad67","name":"30s","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":248,"y":550,"wires":[["42e1db28.6e5834"]]},{"id":"1972140d.52346c","type":"mqtt out","z":"a5076ea7.7ad67","name":"features/manualrec/stop","topic":"instar/local/features/manualrec/stop/raw","qos":"1","retain":"","broker":"ac792e24.b9ef3","x":612,"y":550,"wires":[]},{"id":"42e1db28.6e5834","type":"change","z":"a5076ea7.7ad67","name":"{\"val\":\"off\"}","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":408,"y":550,"wires":[["1972140d.52346c"]]},{"id":"e6ddab7a.b5b568","type":"change","z":"a5076ea7.7ad67","name":"right","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":415,"y":271,"wires":[["9ef72c0f.935c4"]]},{"id":"3f0b1d37.2f7372","type":"switch","z":"a5076ea7.7ad67","name":"Info","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Info","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":231,"y":624,"wires":[["94c8802.fe1cf8"]]},{"id":"374425dd.eebaba","type":"mqtt out","z":"a5076ea7.7ad67","name":"alarm/pushalarm","topic":"instar/local/alarm/pushalarm/raw","qos":"1","retain":"","broker":"ac792e24.b9ef3","x":627,"y":624,"wires":[]},{"id":"94c8802.fe1cf8","type":"change","z":"a5076ea7.7ad67","name":"1","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":379,"y":624,"wires":[["374425dd.eebaba"]]},{"id":"2be0b813.29d1b8","type":"fakeroku-config","z":"","ip":"192.168.2.111","multicast":"239.255.255.250","uuid":"c1db5f4a35fd72dd8b9c5ec0a9dc696d","port":"9086"},{"id":"ac792e24.b9ef3","type":"mqtt-broker","z":"","name":"192.168.2.117 (PrivCert)","broker":"192.168.2.117","port":"8883","tls":"33d22969.642746","clientid":"nodered","usetls":true,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"33d22969.642746","type":"tls-config","z":"","name":"192.168.2.117 (PrivCert)","cert":"","key":"","ca":"","certname":"client.pem","keyname":"","caname":"","servername":"","verifyservercert":false}]
Beispiel: Auf Knopfdruck alle Alarmbereiche deaktivieren und Kamera zur Wand drehen, bevor man das Wohnzimmer betritt:
homee INSTAR Harmony dank INSTAR MQTT
Und @Micha, das schaue ich mir gerne mal an!
