ich wollte mich jetzt auch mal mit Node-Red Homee-in-Homee und Mqtt beschäffitgen.
Ich versuche ein Mqtt Device in Homee abzubilden, eingebunden habe ich schon über Mqtt-Node-red und Homee-in-Homee klappt auch aber ich probiere jetzt wirklich schon seit etlichen Stunden einen Wert in ein “HomeeDevice” zu bekommen aber nichts klappt, denn ich bekomme immer diese Fehlermeldung egal was ich versuche:
payload.id and payload.value must be numeric. ignoring message
ich würde mal hier mein Flow einstellen und vielleicht kann mir hier jemand sagen wo der Fehler ist?!?
[{"id":"7e21ae5f.e1db9","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"deba8c5f.fd207","type":"mqtt in","z":"7e21ae5f.e1db9","name":"","topic":"shellies/shellydimmer-DB3FB5/light/0/status","qos":"2","datatype":"auto","broker":"2355f703.04cfd8","x":170,"y":580,"wires":[["756a337.9b826cc"]]},{"id":"8c983035.1d3c6","type":"comment","z":"7e21ae5f.e1db9","name":"Simulation zigbee3mqtt (IDs 400 - 440)","info":"","x":150,"y":520,"wires":[]},{"id":"26c3b9a6.743166","type":"debug","z":"7e21ae5f.e1db9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":870,"y":240,"wires":[]},{"id":"756a337.9b826cc","type":"change","z":"7e21ae5f.e1db9","name":"Test30","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":320,"wires":[["4a4ddb92.ace684"]]},{"id":"4a4ddb92.ace684","type":"homeeDevice","z":"7e21ae5f.e1db9","virtual-homee":"","name":"Test90","nodeId":"7","profile":"10","icon":"default","attributes":"[{\"id\":700,\"node_id\":7,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"}]","x":570,"y":280,"wires":[["26c3b9a6.743166"]]},{"id":"2355f703.04cfd8","type":"mqtt-broker","z":"","name":"HFS","broker":"192.168.178.102","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Ich hoffe mir könnte auch jemand erklären warum das nicht geht, denn mein Kopf glüht schon…
Mfg Katja
Hab das jetzt schon mehrmals probiert. Leider ohne Erfolg.
