Ich hoffe, dass das so richtig ist. Habe noch nie einen Flow exportiert:
[{"id":"4221cf13.b2831","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"8e6c403c.0be56","type":"hue-motion","z":"4221cf13.b2831","name":"Flur Sensor","bridge":"93be910b.74509","sensorid":"4","x":130,"y":120,"wires":[["1677156b.f11c7b"]]},{"id":"f612819e.be651","type":"homeeDevice","z":"4221cf13.b2831","homee-sim":"e00dee21.773bc","name":"Bewegungsmelder","nodeId":"50","profile":"4015","icon":"default","attributes":"[{\"id\":50,\"node_id\":50,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":51,\"node_id\":50,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"%25\",\"step_value\":1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":52,\"node_id\":50,\"instance\":0,\"minimum\":153,\"maximum\":500,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"K\",\"step_value\":1,\"editable\":1,\"type\":42,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":53,\"node_id\":50,\"instance\":0,\"minimum\":0,\"maximum\":16777215,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":23,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"7001020%3B16419669%3B12026363%3B16525995\"}]","x":990,"y":120,"wires":[[]]},{"id":"1677156b.f11c7b","type":"change","z":"4221cf13.b2831","name":"","rules":[{"t":"change","p":"payload.motion","pt":"msg","from":"true","fromt":"bool","to":"1","tot":"num"},{"t":"change","p":"payload.motion","pt":"msg","from":"false","fromt":"bool","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":120,"wires":[["1aefdd65.3a78b3"]]},{"id":"1aefdd65.3a78b3","type":"function","z":"4221cf13.b2831","name":"Filter Sensor","func":"node.send({payload:{\"id\":50,\"value\":msg.payload.motion}})\nnode.send({payload:{\"id\":51,\"value\":msg.payload.active}})","outputs":1,"noerr":0,"x":650,"y":120,"wires":[["f612819e.be651"]]},{"id":"93be910b.74509","type":"hue-bridge","z":"","name":"hue bridge","bridge":"192.168.178.23","key":"H1FSO2TfPYqpLDGNxIWmLYjHa4yTfe9zWpCbkzsB","interval":"3000"},{"id":"e00dee21.773bc","type":"virtualHomee","z":"","name":"Vhomee"}]
