Moin,
ja, die Verbrauchsdaten sind kein Problem, sofern der Plug sie unterstützt… Meine Teckin können das nicht.
Ich habe aber andere Plugs, mit denen ich das umgesetzt habe. Hier mal mein Flow…
[{"id":"a5f8e542.bf2138","type":"Sonoff device","z":"c9962df.09d63d","mode":"0","broker":"9c3e7001.79fef8","device":"SpMa","name":"","onValue":"ON","offValue":"OFF","cmdPrefix":"cmnd","statPrefix":"stat","telePrefix":"tele","x":630,"y":1760,"wires":[["4feeb3e0.a93354"]]},{"id":"936a6a88.ac60c8","type":"change","z":"c9962df.09d63d","name":"","rules":[{"t":"change","p":"payload.targetValue","pt":"msg","from":"0","fromt":"num","to":"false","tot":"bool"},{"t":"change","p":"payload.targetValue","pt":"msg","from":"1","fromt":"num","to":"true","tot":"bool"},{"t":"move","p":"payload.targetValue","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":1760,"wires":[["a5f8e542.bf2138"]]},{"id":"4feeb3e0.a93354","type":"function","z":"c9962df.09d63d","name":"Rückkanal on off","func":"if (msg.payload === true)\n return {payload:{\"attribute\":{\"id\":130,\"value\":1}}};\nif (msg.payload === false)\n return {payload:{\"attribute\":{\"id\":130,\"value\":0}}};","outputs":1,"noerr":0,"x":830,"y":1760,"wires":[["ef5455d.8f3fba8"]]},{"id":"6154784e.add998","type":"mqtt in","z":"c9962df.09d63d","name":"","topic":"tele/SpMa/SENSOR","qos":"2","datatype":"auto","broker":"9ec0115c.8f7488","x":210,"y":1700,"wires":[["c1b41da9.91c858"]]},{"id":"c1b41da9.91c858","type":"json","z":"c9962df.09d63d","name":"","property":"payload","action":"","pretty":false,"x":470,"y":1700,"wires":[["9354c71.28f72b8"]]},{"id":"9354c71.28f72b8","type":"function","z":"c9962df.09d63d","name":"Filter Energy","func":"var power = msg.payload.ENERGY.Power\nvar total = msg.payload.ENERGY.Total\n\nnode.send({payload:{\"attribute\":{\"id\":131,\"value\":msg.payload.ENERGY.Power}}})\nnode.send({payload:{\"attribute\":{\"id\":132,\"value\":msg.payload.ENERGY.Total}}})","outputs":1,"noerr":0,"x":630,"y":1700,"wires":[["ef5455d.8f3fba8"]]},{"id":"ef5455d.8f3fba8","type":"homeeDevice","z":"c9962df.09d63d","virtual-homee":"","name":"Spülmaschine","nodeId":"130","profile":"13","icon":"nodeicon_washingmachine","attributes":"[{\"id\":130,\"node_id\":130,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":131,\"node_id\":130,\"instance\":0,\"minimum\":0,\"maximum\":3000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"W\",\"step_value\":0.5,\"editable\":0,\"type\":3,\"state\":1,\"last_changed\":1572619585,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":132,\"node_id\":130,\"instance\":0,\"minimum\":0,\"maximum\":50000,\"current_value\":8.85,\"target_value\":8.85,\"last_value\":8.84,\"unit\":\"kWh\",\"step_value\":1,\"editable\":0,\"type\":4,\"state\":1,\"last_changed\":1572807225,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"}]","x":200,"y":1760,"wires":[["936a6a88.ac60c8"]]},{"id":"9c3e7001.79fef8","type":"mqtt-broker","z":"","name":"","broker":"192.168.1.27","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","willTopic":"","willQos":"0","willRetain":"false","willPayload":""},{"id":"9ec0115c.8f7488","type":"mqtt-broker","z":"","name":"","broker":"192.168.1.27","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Mit der Tasmota-FW werden Sensordaten über MQTT übermittelt. Siehst du auch, wenn du auf der Device-Seite bist und unter Console schaust.
Je nach Gerät, kann es sein, dass du auch ein Template anlegen oder abändern musst. Eine gute Übersicht findet man hier:
Außerdem ist die Seite der Tasmota FW interessant. Hier findet man einen guten Überblick über Features und Commands.
