Klar.
"id": "342106b1.5fe48a",
"type": "homeeDevice",
"z": "307fd425.05802c",
"virtual-homee": "",
"name": "Heizung Wohnzimmer",
"nodeId": "360",
"showNodeId": true,
"profile": "3004",
"icon": "nodeicon_radiator",
"attributes": [
"instance": 0,
"minimum": 0,
"maximum": 10000,
"current_value": 0,
"target_value": 0,
"last_value": 0,
"unit": "text",
"step_value": 1,
"editable": 0,
"type": 44,
"state": 1,
"last_changed": 1543522914,
"changed_by": 1,
"changed_by_id": 0,
"based_on": 1,
"data": "1.23",
"id": 360,
"node_id": 360
"instance": 0,
"minimum": 4,
"maximum": 25,
"current_value": 5,
"target_value": 5,
"last_value": 5,
"unit": "%C2%B0C",
"step_value": 1,
"editable": 0,
"type": 5,
"state": 1,
"last_changed": 1573711842,
"changed_by": 1,
"changed_by_id": 0,
"based_on": 1,
"data": "",
"id": 362,
"node_id": 360
"instance": 0,
"minimum": 4,
"maximum": 25,
"current_value": 5,
"target_value": 5,
"last_value": 5,
"unit": "%C2%B0C",
"step_value": 1,
"editable": 1,
"type": 6,
"state": 1,
"changed_by": 1,
"changed_by_id": 0,
"based_on": 1,
"data": "",
"id": 363,
"node_id": 360
"instance": 0,
"minimum": 0,
"maximum": 100,
"current_value": 21,
"target_value": 21,
"last_value": 21,
"unit": "n%2Fa",
"step_value": 1,
"editable": 0,
"type": 7,
"state": 1,
"changed_by": 1,
"changed_by_id": 0,
"based_on": 1,
"data": "",
"id": 364,
"node_id": 360
"statusTemplate": "",
"x": 720,
"y": 880,
"wires": [
"3235f30e.e915fc"
"id": "b9fc7fc9.8e35e",
"type": "ioBroker in",
"name": "Value.Temperature",
"topic": "tado.0.290480.Rooms.4.Actual_Temperature",
"payloadType": "value",
"onlyack": "",
"func": "all",
"gap": "",
"x": 150,
"y": 820,
"wires": [
"36cb2b7.481b0d4"
"id": "743245f4.6ac24c",
"type": "function",
"name": "Funktion on off",
"func": "Temp = msg.payload;\nreturn {payload:{\"attribute\":{\"id\":362,\"value\": Temp}}};",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 480,
"y": 820,
"wires": [
"342106b1.5fe48a"
"id": "5b91472d.62a688",
"topic": "tado.0.290480.Rooms.4.setting.temperature",
"onlyack": "",
"func": "all",
"gap": "",
"x": 150,
"y": 860,
"wires": [
"a4ce1f49.50a1d"
"id": "3d81a59.f24665a",
"type": "function",
"func": "Temp = msg.payload;\nreturn {payload:{\"attribute\":{\"id\":363,\"value\": Temp}}};",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 480,
"y": 860,
"wires": [
"342106b1.5fe48a"
"id": "36cb2b7.481b0d4",
"type": "json",
"name": "",
"property": "payload",
"action": "",
"pretty": false,
"x": 330,
"y": 820,
"wires": [
"743245f4.6ac24c"
"id": "a4ce1f49.50a1d",
"type": "json",
"name": "",
"action": "",
"pretty": false,
"x": 330,
"y": 860,
"wires": [
"3d81a59.f24665a"
"id": "7b0049d3.547d38",
"type": "template",
"name": "",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "{{payload.targetValue}}",
"output": "str",
"x": 1040,
"y": 840,
"wires": [
"184c60e5.d7884f"
"id": "184c60e5.d7884f",
"type": "ioBroker out",
"name": "Temperature",
"ack": "false",
"autoCreate": "false",
"stateName": "",
"role": "",
"stateUnit": "",
"stateMin": "",
"stateMax": "",
"x": 1190,
"y": 840,
"wires": []
"id": "ed5a4aad.37a618",
"name": "Current Fw Version",
"topic": "tado.0.290480.Rooms.4.devices.RU3104574464.info.currentFwVersion",
"onlyack": "",
"func": "all",
"gap": "",
"x": 150,
"y": 900,
"wires": [
"1178c545.9c37f3"
"id": "7cfbad63.e43ff4",
"name": "Luftfeuchtigkeit",
"topic": "tado.0.290480.Rooms.4.Actual_Humidity",
"onlyack": "",
"func": "all",
"gap": "",
"x": 140,
"y": 940,
"wires": [
"e4c723.89eb78e"
"id": "e4c723.89eb78e",
"type": "json",
"name": "",
"action": "",
"pretty": false,
"x": 330,
"y": 940,
"wires": [
"317ad69e.27dfca"
"id": "317ad69e.27dfca",
"type": "function",
"func": "Temp = msg.payload;\nreturn {payload:{\"attribute\":{\"id\":364,\"value\": Temp}}};",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 480,
"y": 940,
"wires": [
"342106b1.5fe48a"
"id": "3235f30e.e915fc",
"type": "switch",
"name": "",
"property": "payload.attributeId",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "362",
"vt": "num"
"t": "eq",
"v": "363",
"vt": "num"
"t": "eq",
"v": "360",
"vt": "num"
"t": "eq",
"v": "364",
"vt": "num"
"t": "eq",
"v": "365",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 5,
"x": 910,
"y": 860,
"wires": [
"7b0049d3.547d38"
"fe418c83.48763"
"id": "fe418c83.48763",
"type": "function",
"name": "Reset",
"func": "return {payload: true};",
"outputs": 1,
"noerr": 0,
"x": 1030,
"y": 880,
"wires": [
"8be7a9f1.d3b358"
"id": "8be7a9f1.d3b358",
"topic": "tado.0.290480.Rooms.4.overlay.clearZoneOverlay",
"ack": "false",
"x": 1170,
"y": 880,
"wires": []
"id": "1178c545.9c37f3",
"type": "function",
"name": "Set Software",
"func": "var firmware = parseFloat(msg.payload);\nmsg.payload = {\"attribute\":{ \"id\":360, \"value\": firmware}};\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 350,
"y": 900,
"wires": [
"342106b1.5fe48a"
