Suche Schaltereinsatz für Merten Programm
Dann habe ich das irgendwie falsch verstanden. Wäre ja auch Quatsch, an dieser Stelle einen Dimmer einzubauen, um die Lampe an bzw. aus zu schalten.
Die Einstellungen in der App-Oberfläche betreffen dann wohl den Parameter 1, der sich getrennt für beide Schalter einstellen läßt. Ich finde allerdings keinen Parameter, der diese Verzögerung von 3s erklären könnte.
An der Stelle muss ich leider passen. Hier nochmal die Parameterliste von der Qubino-Webseite:
Setting Parameters
Parameter no. 1 & no. 2 – Input I1 & Input I2 switch type
Available configuration parameters (data type is 1 Byte DEC):
  • default value 1
  • 0 - mono-stable switch type (push button)
  • 1 - bi-stable switch type
Flush-2-relays-NEW-Q1-and-Q2
Parameter no. 11 & no. 13 - Automatic turning off output Q1 & Q2 after set time
TVs, Hi-Fi systems and other home appliances have already integrated automatic turn off functionality, this device also offers this functionality. Automatic turning off function allows energy saving, without doing scenes on Z-Wave controller.
This function, for example also allows automatic re-locking door after defined time.
When relay Q1 or Q2 is ON it goes automatically OFF after time defined by this parameter. Timer is reset to zero each time the device receives ON command regardless from where it comes (push button, associated device, gateway, controller, etc.).
Available configuration parameters (data type is 2 Byte DEC):
  • Default value 0
  • 0 - Auto OFF disabled
  • 1 – 32535 = 1 second (0,01 s) – 32535 seconds (325,35 s) Auto OFF enabled with define time, step is 1 s or 10 ms according to parameter nr. 15
Parameter no. 12 & no. 14 - Automatic turning on output Q1 & Q2 after set time
When relay Q1 or Q2 is OFF it goes automatically ON after time defined by this parameter. Timer is reset to zero each time the device receives OFF command regardless from where it comes (push button, associated device, gateway, controller, etc.).
  • Default value 0
  • 0 - Auto ON disabled
  • 1 – 32535 = 1 second (0,01 s) – 32536 seconds (325,35 s) Auto ON enabled with define time, step is 1 s or 10 ms according to parameter nr. 15
Parameter no. 15 - Automatic turning off / on seconds or milliseconds selection
  • Default value 0
  • 0 – seconds selected
  • 1 – milliseconds selected
Note: This parameter is valid for both outputs Q1, Q2 and is the same for turning off or on.
Parameter no. 30 - Saving the state of the relays Q1 and Q2 after a power failure
  • default value 0
  • 0 – Flush 2 Relay device saves its state before power failure (it returns to the last position saved before a power failure)
  • 1 - Flush 2 Relay device does not save the state after a power failure, it returns to “off” position.
Parameter no. 40 & no. 41– Power reporting in Watts on power change for Q1 or Q2
Set value means percentage, set value from 0 – 100 = 0 % - 100 %. Available configuration parameters (data type is 1 Byte DEC):
  • default value 10
  • 0 – Reporting Disabled
  • 1 – 100 = 1 % - 100 % Reporting enabled. Power report is sent (pushed) only when actual power in Watts in real time changes for more than set percentage comparing to previous actual power in Watts, step is 1 %.
Note: If power changed is less than 1 W, the report is not sent (pushed), independent of percentage set.
Parameter no. 42 & no. 43– Power reporting in Watts by time interval for Q1 or Q2
Set value means time interval (0 – 32535) in seconds, when power report is sent. Available configuration parameters (data type is 2 Byte DEC):
  • default value 300 (power report in Watts is sent each 300 s)
  • 1 – 32535 = 1 second – 32535 seconds. Reporting enabled. Power report is sent with time interval set by entered value.
Some valves are normally opened (NO), some are normally closed (NC).
NO - if the power is off, the valve is open
NC - if the power is off, the valve is closed
Parameter no. 63 & no. 64 – Output Q1 & Output Q2 Switch selection
Set value means the type of the device that is connected to the PWM output. The device type can be normally open (NO) or normally close (NC). Available configuration parameters (data type is 1 Byte DEC):
  • default value 0
  • 0 - When system is turned off the output is 0 V (NC).
  • 1 - When system is turned off the output is 230 V (NO).
Temperature Sensor Setting
Parameter no. 110 – Temperature sensor offset settings
If the temperature sensor is connected to the device, the temperature sensor widget is shown automatically in UI (user interface).
If the measured temperature with an additional temperature measuring device is different from the one measured by the connected digital temperature sensor, the temperature can be compensated by this parameter.
  • default value 32536
  • 32536 – offset is 0.0 °C
  • From 1 to 100 – value from 0.1 °C to 10.0 °C is added to actual measured temperature.
Parameter no. 120 – Digital temperature sensor reporting
If digital temperature sensor is connected, device reports measured temperature on temperature change defined by this parameter.
Available configuration para meters (data type is 1 Byte DEC):
  • Default value 5 (Temperature is reported on 0.5 °C change)
  • 0 – Reporting disabled
  • 1- 127 = 0.1 °C – 12.7 °C, step is 0.1 °C
Ich würde ein neu abfragen versuchen. Sonst würde ich den Aktor einmal ausbinden. Nach Qubino Anleitung resetten und dann neu anlernen.
Hörst du das Relay im Qubino, sofort schalten?
Wenn der Qubino Aus ist und du über die App schaltest, dauert es auch 3 Sekunden bis in der Zeile über dem Webschalter An angezeigt wird?
Alternativ mal über das homeean online terminal einen trace fahren?
https://homeean.de/terminal
Das habe ich bereits versucht. Hast leider nichts gebracht
Wenn ich den Qubino über die Smartphone app schalte, dann klickt das Relais sofort und die Lichter gehen sofort an/aus. Auf der WebApp im Browser wechsel die Schalter sofort.
Hier der Code vom einschalten:
{"attribute":{"id":71,"node_id":8,"instance":0,"minimum":0,"maximum":100,"current_value":100.0,"target_value":100.0,"last_value":100.0,"unit":"%25","step_value":1.0,"editable":1,"type":15,"state":1,"last_changed":1541105924,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","options":[]}}
{“attribute”:{“id”:72,“node_id”:8,“instance”:0,“minimum”:0,“maximum”:4,“current_value”:1.0,“target_value”:1.0,“last_value”:1.0,“unit”:"",“step_value”:1.0,“editable”:1,“type”:135,“state”:1,“last_changed”:1541105924,“changed_by”:1,“changed_by_id”:0,“based_on”:1,“data”:"",“options”:[]}}
{“homeegram”:{“id”:18,“name”:“Wohn%20an”,“image”:“homeegramicon_bulb_value_1”,“state”:2,“visible”:1,“favorite”:0,“order”:6,“active”:1,“play”:1,“added”:1541084675,“services”:255,“phonetic_name”:"",“note”:"",“last_triggered”:1541105925,“owner”:1,“triggers”:{“time_triggers”:[],“attribute_triggers”:[{“id”:24,“homeegram_id”:18,“node_id”:15,“attribute_id”:123,“operator”:3,“value”:1.0}],“webhook_triggers”:[],“homeegram_triggers”:[],“celestial_triggers”:[],“switch_trigger”:0},“conditions”:{“time_conditions”:[],“attribute_conditions”:[],“homeegram_conditions”:[],“celestial_conditions”:[]},“actions”:{“attribute_actions”:[{“id”:47,“homeegram_id”:18,“delay”:0,“node_id”:9,“attribute_id”:88,“source_attribute_id”:0,“value”:1.0,“options”:{}}],“group_actions”:[],“tts_actions”:[],“notification_actions”:[],“webhook_actions”:[],“homeegram_actions”:[]}}}
{“attribute”:{“id”:123,“node_id”:15,“instance”:1,“minimum”:0,“maximum”:1,“current_value”:1.0,“target_value”:1.0,“last_value”:0.0,“unit”:"",“step_value”:1.0,“editable”:1,“type”:1,“state”:1,“last_changed”:1541105925,“changed_by”:1,“changed_by_id”:0,“based_on”:1,“data”:"",“options”:[]}}
{“homeegram”:{“id”:18,“name”:“Wohn%20an”,“image”:“homeegramicon_bulb_value_1”,“state”:1,“visible”:1,“favorite”:0,“order”:6,“active”:1,“play”:0,“added”:1541084675,“services”:255,“phonetic_name”:"",“note”:"",“last_triggered”:1541105925,“owner”:1,“triggers”:{“time_triggers”:[],“attribute_triggers”:[{“id”:24,“homeegram_id”:18,“node_id”:15,“attribute_id”:123,“operator”:3,“value”:1.0}],“webhook_triggers”:[],“homeegram_triggers”:[],“celestial_triggers”:[],“switch_trigger”:0},“conditions”:{“time_conditions”:[],“attribute_conditions”:[],“homeegram_conditions”:[],“celestial_conditions”:[]},“actions”:{“attribute_actions”:[{“id”:47,“homeegram_id”:18,“delay”:0,“node_id”:9,“attribute_id”:88,“source_attribute_id”:0,“value”:1.0,“options”:{}}],“group_actions”:[],“tts_actions”:[],“notification_actions”:[],“webhook_actions”:[],“homeegram_actions”:[]}}}
{“attribute”:{“id”:88,“node_id”:9,“instance”:0,“minimum”:0,“maximum”:1,“current_value”:0.0,“target_value”:1.0,“last_value”:0.0,“unit”:“n%2Fa”,“step_value”:1.0,“editable”:1,“type”:1,“state”:4,“last_changed”:1541105872,“changed_by”:3,“changed_by_id”:0,“based_on”:1,“data”:"",“options”:[]}}
{“attribute”:{“id”:88,“node_id”:9,“instance”:0,“minimum”:0,“maximum”:1,“current_value”:1.0,“target_value”:1.0,“last_value”:0.0,“unit”:“n%2Fa”,“step_value”:1.0,“editable”:1,“type”:1,“state”:1,“last_changed”:1541105926,“changed_by”:1,“changed_by_id”:0,“based_on”:1,“data”:"",“options”:[]}}
+push+
jemand noch eine Idee woran es liegen könnte?
Hey Leute, würde das Problem gerne irgendwie mit eurer Hilfe lösen wollen.
Hat jemand vielleicht noch eine Idee, woran das liegen könnte?
Hast du andere Geräte, die Zofen Hintergrundrauschen veranstalten? Mit dem terminal könnte man das sehen
Und wie viele HG laufen denn im Hintergrund?
Wenn dort einiges aktiv ist - deaktiviere mal schrittweise probehalber
Habe schon mal geschrieben, dass ich alle HGs deaktiviert habe und den Schalter direkt neben dem homee gehalten habe.
Auch da hatte ich eine 3 sek Verzögerung beim Schalten
welche anderen Z-Wave-Geräte sind noch im System?
Es sind noch 2 Fibaro Rolladen Schalter FGR-222 angeschlossen
So, heute habe ich den FGS-212 von Fibaro erhalten und eingebaut. Das Teil funktioniert genauso, wie erwartet!!!
Das Ding von Qubino geht jetzt zurück. Damit hat die Sache endlich ein Ende.
Ich war echt enttäuscht. Dachte ich müsste mit den Verzögerungen leben…
