With Qubino Flush 1D Relay you can wirelessly control your garage door, gate or entrance door of different power supply (110-240 VAC or 24 VDC). Use it to manage your gas water heater or as an intermediary that sends a PV signal to your heat pump, so it starts using photovoltaics energy and heating water to a higher temperature.
No sensor connectedand no homekit.
And the Qubino (connected to hörmann Garage door) in homee is just like a „smart remote control“.
So more like a smart button to push to open/close/stop the garage door.
You dont have informationen about the state of the door with just the qubino in use.
Thanks for feedback. I guess you have connected Qubino to the Garage door button connectors on the garage door motor, right?
If you say it only works as mommentary switch Start/Stop function, I guess it would make sense for Homee to include this device, and give it a possibility to work as a garage door opener with garage door status if sensor is connected.
Sort of in a way, like Qubino is advertising it on theiur webpage
Qubino has a very good manual for the relay (approx. 70 pages) with all parameters described.
I think I solved it for my garage with the following parameter (expert setting)
Edit: Had a quick look and saw that I can choose between a switch and a button direct in the homee App. So there might be no need for setting parameters.
