Versuche doch mal diese beiden Geräte…
[{"id":"6d904d8a.5c3864","type":"homeeDevice","z":"fd6d95c1.d70ae8","virtual-homee":"","name":"Hue Iris rechts","nodeId":"10","profile":"1001","icon":"","attributes":"[{\"id\":10,\"node_id\":10,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":11,\"node_id\":10,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"%25\",\"step_value\":1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":12,\"node_id\":10,\"instance\":0,\"minimum\":0,\"maximum\":16777215,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":23,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"7001020%3B16419669%3B12026363%3B16525995\"}]","x":180,"y":480,"wires":[["9541487a.2ccda8"]]},{"id":"74e11847.befdb8","type":"homeeDevice","z":"fd6d95c1.d70ae8","virtual-homee":"","name":"Hue Iris links","nodeId":"20","profile":"1001","icon":"","attributes":"[{\"id\":20,\"node_id\":20,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":21,\"node_id\":20,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"%25\",\"step_value\":1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":22,\"node_id\":20,\"instance\":0,\"minimum\":0,\"maximum\":16777215,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":23,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"7001020%3B16419669%3B12026363%3B16525995\"}]","x":170,"y":540,"wires":[["9afddfe6.67f52"]]}]
nach dem Import noch bitte oben deinen virtuellen homie auswählen.
