"id": "bd685447.6c6e68",
"type": "homeeDevice",
"z": "fa55b618.3bc518",
"virtual-homee": "",
"name": "heatit",
"nodeId": "1056",
"profile": "3006",
"icon": "default",
"attributes": "[{\"id\":2802,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":255,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":0,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2803,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"on/off\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":0,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2804,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":0,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"text\",\"step_value\":1,\"editable\":0,\"type\":44,\"state\":1,\"last_changed\":0,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"5.03\"},{\"id\":2805,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":0,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"text\",\"step_value\":1,\"editable\":0,\"type\":45,\"state\":1,\"last_changed\":0,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"3.04\"},{\"id\":2806,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":50000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"kWh\",\"step_value\":1,\"editable\":0,\"type\":4,\"state\":1,\"last_changed\":1586200527,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2807,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":100,\"target_value\":100,\"last_value\":0,\"unit\":\"%25\",\"step_value\":1,\"editable\":0,\"type\":8,\"state\":1,\"last_changed\":1586180584,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2808,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":4,\"current_value\":4,\"target_value\":4,\"last_value\":4,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":258,\"state\":1,\"last_changed\":1586199072,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2809,\"node_id\":1056,\"instance\":0,\"minimum\":5,\"maximum\":35,\"current_value\":21,\"target_value\":21,\"last_value\":22.5,\"unit\":\"%C2%B0C\",\"step_value\":0.5,\"editable\":1,\"type\":6,\"state\":1,\"last_changed\":1586199069,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\",\"options\":{\"automations\":[\"step\"]}},{\"id\":2810,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":3500,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"W\",\"step_value\":1,\"editable\":0,\"type\":3,\"state\":1,\"last_changed\":1586200527,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2811,\"node_id\":1056,\"instance\":0,\"minimum\":0,\"maximum\":250,\"current_value\":238.1,\"target_value\":238.1,\"last_value\":238.8,\"unit\":\"V\",\"step_value\":1,\"editable\":0,\"type\":195,\"state\":1,\"last_changed\":1586200527,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2812,\"node_id\":1056,\"instance\":0,\"minimum\":-50,\"maximum\":125,\"current_value\":22.799,\"target_value\":22.799,\"last_value\":22.799,\"unit\":\"%C2%B0C\",\"step_value\":1,\"editable\":0,\"type\":315,\"state\":1,\"last_changed\":1586200527,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":2813,\"node_id\":1056,\"instance\":0,\"minimum\":-50,\"maximum\":125,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"%C2%B0C\",\"step_value\":1,\"editable\":0,\"type\":316,\"state\":1,\"last_changed\":1586200528,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"}]",
"x": 550,
"y": 360,
"wires": [
"40d5b99b.d87a88",
"889efb92.0ada88",
"a343c30e.9777f"
probiere mal bitte dieses Thermostat ( heatit )
Hier wird das selbe Attribut sauber angezeigt.
