Also falls jemand über dieselbe Herausforderung stolpert, wie ich, die Homematic IP Geräte über die CCU einzubinden, hier die Flows für das Raumthermostat und das Heizungsthermostat. Endlich geschafft
Raumthermostat WTH-2
[{"id":"895ec120.51cab","type":"homeeDevice","z":"c7696333.f10fe","virtual-homee":"","name":"Raumthermostat Template","nodeId":"","showNodeId":true,"profile":"3004","icon":"default","attributes":[{"state":1,"instance":0,"minimum":0,"maximum":100,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"n/a","step_value":1,"editable":1,"last_changed":1603229606,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":40,"type":2,"node_id":null},{"state":1,"instance":0,"minimum":0,"maximum":28,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"°C","step_value":0.5,"editable":1,"last_changed":1603229612,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":41,"type":6,"node_id":null},{"state":1,"instance":0,"minimum":-50,"maximum":125,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"°C","step_value":0.5,"editable":0,"last_changed":1603229617,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":42,"type":5,"node_id":null},{"state":1,"instance":0,"minimum":0,"maximum":100,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"n/a","step_value":1,"editable":0,"last_changed":1603229636,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":43,"type":7,"node_id":null},{"state":1,"instance":0,"minimum":0,"maximum":1,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"n/a","step_value":1,"editable":0,"last_changed":1603229641,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":44,"type":69,"node_id":null}],"statusTemplate":"","x":640,"y":400,"wires":[[]]}]
Heizungsthermostat eTRV2
[{"id":"4410fad0.dc0d14","type":"homeeDevice","z":"c7696333.f10fe","virtual-homee":"","name":"Heizung","nodeId":"60","showNodeId":true,"profile":"3006","icon":"default","attributes":[{"state":1,"instance":0,"minimum":0,"maximum":100,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"n/a","step_value":1,"editable":1,"last_changed":1603229606,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":60,"type":2,"node_id":60},{"state":1,"instance":0,"minimum":0,"maximum":28,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"°C","step_value":0.5,"editable":1,"last_changed":1603229612,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":61,"type":6,"node_id":60},{"state":1,"instance":0,"minimum":0,"maximum":1,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"n/a","step_value":1,"editable":0,"last_changed":1603229641,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":64,"type":69,"node_id":60},{"state":1,"instance":0,"minimum":0,"maximum":100,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"n/a","step_value":1,"editable":1,"last_changed":1603230319,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":63,"type":18,"node_id":60},{"state":1,"instance":0,"minimum":-50,"maximum":125,"current_value":0,"target_value":0,"last_value":0,"data":"","unit":"°C","step_value":0.5,"editable":0,"last_changed":1603232418,"changed_by":1,"changed_by_id":0,"based_on":1,"options":[],"id":62,"type":5,"node_id":60}],"statusTemplate":"","x":750,"y":1680,"wires":[["d30d7a19.99b448"]]}]
