"id": "4b954ec7.0bcc9",
"type": "homeeDevice",
"z": "76b6d694.226ff8",
"virtual-homee": "",
"name": "Rechner",
"nodeId": "40",
"profile": "15",
"icon": "default",
"attributes": "[{\"id\":40,\"node_id\":40,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"berechen\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":41,\"node_id\":40,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"Wert1\",\"step_value\":0.1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":42,\"node_id\":40,\"instance\":1,\"minimum\":0,\"maximum\":100,\"current_value\":153,\"target_value\":0,\"last_value\":0,\"unit\":\"Wert2\",\"step_value\":0.1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":43,\"node_id\":40,\"instance\":2,\"minimum\":-50,\"maximum\":1000,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"Ergebniss\",\"step_value\":0.1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":44,\"node_id\":40,\"instance\":3,\"minimum\":0,\"maximum\":7,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"Rechenart +-/*=<>\",\"step_value\":1,\"editable\":1,\"type\":2,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"},{\"id\":45,\"node_id\":40,\"instance\":1,\"minimum\":0,\"maximum\":1,\"current_value\":0,\"target_value\":0,\"last_value\":0,\"unit\":\"Wahr/Falsch\",\"step_value\":1,\"editable\":1,\"type\":1,\"state\":1,\"last_changed\":12345555,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":1,\"data\":\"\"}]",
"x": 240,
"y": 400,
"wires": [
"7f10cd8c.2c4824",
"7a44e3b6.eeb1bc",
"90fa6d31.42392",
"ff6a76c4.130958"
This file has been truncated. show original
