**Name des Produktes: Fibaro Walli Double Switch
**Hersteller: Fibaro
**Technologie: Z-Wave
**Preis: ca. 50,-
**Funktionen (z.B.: Bewegungsmelder, Temperatursensor, Sirene…): Double Switch
**Link: https://www.fibaro.com/de/products/smart-switches-and-outlets-walli-switch/
**Weitere Infos:
POWER AND INSTALLATION
Power Supply: 110-230V~ 50/60 Hz
Recommended external overcurrent protection:
10A type B circuit breaker (EU)
13A type B circuit breaker (Sweden)
Active element: micro-gap relay μ
Recommended wires:
cross-section area between 1.5-4.0mm2
For installation in flush-mounted boxes:
Ø = 60mm
depth ≥ 40mm
Operating temperature: 0-35 °C
Ambient humidity: 10–95% RH without condensation
DEVICE APPLICATIONS
Rated load current:
13A per one channel
16A total
Number of controlled loads:
1/2 (default 2)
Compatible load types:
incandescent
tube laps
LED
electronic transformers
ferromagnetic transformers
COMMUNICATION
Radio protocol: Z-Wave
Transmit power: EIRP max 6dBm
Radio frequency:
868.4 or 869.85 MHz EU
869.0 MHz RU
Range:
up to 50m outdoors
up to 40m indoors
(depending on terrain and building structure)
PACKAGE CONTAINS
Switch Unit FG-WDSEU221-AS-8001
Single cover plate FG-Wx-PP-0001
Switch button with lightguide FG-WDSEU221-AS-8100
Mouting frame FIBARO/Gira55 FG-Wx-AS-4001
Short manual
**Bild:
