Fibaro Roller Shutter 3 and Schellenberg Plus calibration
Hi, I’m new here and would like to share my solution for the problem I had with above hardware. I hope this is in the right part of the community.
A Fibaro Roller Shutter 3 with Firmware 5.01
A Schellenberg roller motor Plus with integrated electronics (no wireless function)
The calibration started, but the first move (upwards) ended and the Fibaro did not make the second move (downwards). The relais did not click, and a check with a multimeter showed that the Q2 output was still ON. The fibaro just did not recognize the end of the movement. Parameters 156 and 157 (time) are not read during calibration.
I did a lot of tests, eventually was the solution to put parameter 155 to value 100. This worked on both my Schellenberg motors with 10Nm and also the other one with 20Nm.
I hope this helps someone.
Hello @desperate251 , i am experiencing the same problems. My Schellenberg motor won’t work with my Fibaro Roller Shutter 3. How many bytes did you select in the expert mode when sending 155 / 100? And did you set any other parameters?
