Fiabro Roller Shutter 4 compatibility
I had to replace one my Qubino roller shutter and installed a Fibaro roller shutter 4 (what I find on the market). But I cannot control the position of the slats Is there any special configuration or is it a lack of compatibility? If yes, will it change soon ?
Don’t think it’s supported officially here.
What version is your zwave Cube? 5 or 7?
I guess 5, never changed it in years.
My problem is the modules are failing and I don’t know how to replace because I don’t find anything 100% compatible on the market. The Fibaro 4 is recognized but without slat movement it is useless. The new Qubino-Shelly seems unknown. Really don’t know what to do. Don’t really wish to get out of Homee. I have another bigger home where I use Home Assistant but it is overkill here.
New Qubino Shelly needs ZWave 700 Chip -Cube which has a few issues and you would need to build up a second mesh
Either you find an older device on eBay or similar, or you try, maybe the Shelly Wi-Fi devices that Homee supports now in broad range
Many postings on the forum for this
