Hallo, nein ich habe den Namen meiner Batterie eingegeben, Nr.1.12v.100Ah
die Entitäten werden im MQQT nicht angezeigt.
Allerdings im MQQT Explorer schon:
Nr.1.12v.100Ah
soc (6 topics, 141 messages)
mosfet_status (1 topic, 14 messages)
meter (7 topics, 99 messages)
cell_voltages (11 topics, 185 messages)
switch (2 topics, 26 messages)
temperatures
die Log files:
11:51:39 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=57910)
11:55:41 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.4%,U=13.0V,I=0.86A,P=11W,Q=13/100Ah,mos=nan°C)
11:55:41 INFO [sampling] Nr.1.12v.100Ah volt=[3249,3260,3255,3266] temp=[10.3, 9.8, 9.7]
11:56:39 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=58169)
12:01:39 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=58429)
12:05:42 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.5%,U=13.0V,I=0.35A,P=5W,Q=13/100Ah,mos=nan°C)
12:05:42 INFO [sampling] Nr.1.12v.100Ah volt=[3249,3261,3256,3266] temp=[10.3, 9.8, 9.7]
12:06:40 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=58686)
12:10:42 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.5%,U=13.0V,I=0.60A,P=8W,Q=14/100Ah,mos=nan°C)
12:10:42 INFO [sampling] Nr.1.12v.100Ah volt=[3249,3261,3256,3266] temp=[10.3, 9.8, 9.7]
12:11:40 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=58944)
12:15:42 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.6%,U=13.0V,I=0.70A,P=9W,Q=14/100Ah,mos=nan°C)
12:15:42 INFO [sampling] Nr.1.12v.100Ah volt=[3250,3262,3256,3267] temp=[10.3, 9.7, 9.7]
12:16:41 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=59205)
12:20:43 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.7%,U=13.0V,I=0.78A,P=10W,Q=14/100Ah,mos=nan°C)
12:20:43 INFO [sampling] Nr.1.12v.100Ah volt=[3250,3262,3257,3267] temp=[10.3, 9.8, 9.7]
12:21:41 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=59464)
12:26:42 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=59724)
12:31:43 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=59982)
12:35:44 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.8%,U=13.0V,I=0.70A,P=9W,Q=14/100Ah,mos=nan°C)
12:35:44 INFO [sampling] Nr.1.12v.100Ah volt=[3251,3263,3257,3268] temp=[10.4, 9.8, 9.8]
12:36:44 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=60241)
12:41:44 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=60500)
12:45:45 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(13.9%,U=13.0V,I=0.26A,P=3W,Q=14/100Ah,mos=nan°C)
12:45:45 INFO [sampling] Nr.1.12v.100Ah volt=[3251,3263,3257,3268] temp=[10.5, 9.8, 9.8]
12:46:44 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=60759)
12:51:45 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=61019)
12:56:46 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=61279)
13:01:47 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=61539)
13:06:47 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=61799)
13:10:48 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(14.0%,U=13.0V,I=0.60A,P=8W,Q=14/100Ah,mos=nan°C)
13:10:48 INFO [sampling] Nr.1.12v.100Ah volt=[3253,3265,3259,3270] temp=[10.6, 9.9, 9.9]
13:11:48 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=62058)
13:15:48 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(14.0%,U=13.0V,I=0.51A,P=7W,Q=14/100Ah,mos=nan°C)
13:15:48 INFO [sampling] Nr.1.12v.100Ah volt=[3253,3265,3260,3270] temp=[10.6, 9.9, 9.9]
13:16:49 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=62316)
13:21:49 INFO [sampling] Sending HA discovery for Nr.1.12v.100Ah (num_samples=62575)
13:25:49 INFO [sampling] Nr.1.12v.100Ah: BmsSampl(14.2%,U=13.1V,I=1.05A,P=14W,Q=14/100Ah,mos=nan°C)
13:25:49 INFO [sampling] Nr.1.12v.100Ah volt=[3256,3268,3263,3273] temp=[10.6, 9.9, 9.9]
