Schon einmal an den PArametern geschraubt?
Siehe hier:
Mit Parameter 5 wäre ich vorsichtig…
Configure the Multisensor 6 using your gateway.
Not all gateways have the ability to configure its devices, this step will require a gateway that can make changes to parameter configuration settings. Ask your gateway support team if your gateway supports manual configuration to Z-Wave devices.
Set these parameter settings:
Parameter 3 [2 byte] = 10 // This will set the timeout of the PIR sensor to 10 seconds
Parameter 4 [1 byte] = 5 // This is the default setting, but sending it in anyways may active the PIR sensor
Parameter 5 [1 byte] = 2 // After setting param 3 and 4, i would test the unit first before setting this. This changes the report type to your gateway.
Now test your Multisensor 6 every 10 seconds, watch to see if the LED on the Multisensor 6 blinks green or blue when you could have potentially triggered its motion sensor.
