ich bekomme regelmäßig die nachricht im log, dass sich der adapter immer wieder disconnected und direkt wieder connected…
|mihome-vacuum.0|2020-08-23 21:56:56.600|info|(1164) Connected|
|mihome-vacuum.0|2020-08-23 21:56:56.515|info|(1164) Disconnect|
|mihome-vacuum.0|2020-08-23 21:56:35.217|info|(1164) Connected|
|mihome-vacuum.0|2020-08-23 21:56:35.127|info|(1164) Disconnect|
ist das normal?
wenn ich den sauger starten möchte, kommt folgende Meldung im Log
(1610) should trigger cleaning all null, but is currently active. Add to queue
Im iobroker Forum kann mir leider auch nicht weiter geholfen werden.
Vielleicht hat jemand von euch noch ne Idee?!?!
Bekomme laufend folgende Meldungen im log:
mihome-vacuum.0 2020-09-06 21:48:34.652 debug (26692) no answer for get_status(id:136) received, giving up
mihome-vacuum.0 2020-09-06 21:48:30.810 debug (26692) no answer for get_sound_volume(id:135) received, giving up
mihome-vacuum.0 2020-09-06 21:48:30.609 debug (26692) no answer for get_clean_summary(id:134) received, giving up
mihome-vacuum.0 2020-09-06 21:48:30.409 debug (26692) no answer for get_consumable(id:133) received, giving up
mihome-vacuum.0 2020-09-06 21:48:26.098 debug (26692) no answer for get_status(id:131) received, giving up
mihome-vacuum.0 2020-09-06 21:48:25.350 debug (26692) no answer for get_status(id:130) received, giving up
mihome-vacuum.0 2020-09-06 21:48:25.203 debug (26692) requesting params every: 10 Sec
mihome-vacuum.0 2020-09-06 21:48:24.650 debug (26692) no answer for get_status(id:129) received, giving up
mihome-vacuum.0 2020-09-06 21:48:20.809 debug (26692) no answer for get_sound_volume(id:128) received, giving up
mihome-vacuum.0 2020-09-06 21:48:20.611 debug (26692) no answer for get_clean_summary(id:127) received, giving up
mihome-vacuum.0 2020-09-06 21:48:20.411 debug (26692) no answer for get_consumable(id:126) received, giving up
mihome-vacuum.0 2020-09-06 21:48:16.095 debug (26692) no answer for get_status(id:124) received, giving up
mihome-vacuum.0 2020-09-06 21:48:15.348 debug (26692) no answer for get_status(id:123) received, giving up
mihome-vacuum.0 2020-09-06 21:48:15.202 debug (26692) requesting params every: 10 Sec
mihome-vacuum.0 2020-09-06 21:48:14.647 debug (26692) no answer for get_status(id:122) received, giving up
mihome-vacuum.0 2020-09-06 21:48:10.814 debug (26692) no answer for get_sound_volume(id:121) received, giving up
mihome-vacuum.0 2020-09-06 21:48:10.611 debug (26692) no answer for get_clean_summary(id:120) received, giving up
mihome-vacuum.0 2020-09-06 21:48:10.410 debug (26692) no answer for get_consumable(id:119) received, giving up
mihome-vacuum.0 2020-09-06 21:48:06.093 debug (26692) no answer for get_status(id:117) received, giving up
mihome-vacuum.0 2020-09-06 21:48:05.344 debug (26692) no answer for get_status(id:116) received, giving up
mihome-vacuum.0 2020-09-06 21:48:05.202 debug (26692) requesting params every: 10 Sec
mihome-vacuum.0 2020-09-06 21:48:04.644 debug (26692) no answer for get_status(id:115) received, giving up
mihome-vacuum.0 2020-09-06 21:48:00.810 debug (26692) no answer for get_sound_volume(id:114) received, giving up
mihome-vacuum.0 2020-09-06 21:48:00.609 debug (26692) no answer for get_clean_summary(id:113) received, giving up
mihome-vacuum.0 2020-09-06 21:48:00.409 debug (26692) no answer for get_consumable(id:112) received, giving up
mihome-vacuum.0 2020-09-06 21:47:56.089 debug (26692) no answer for get_status(id:110) received, giving up
mihome-vacuum.0 2020-09-06 21:47:55.343 debug (26692) no answer for get_status(id:109) received, giving up
mihome-vacuum.0 2020-09-06 21:47:55.201 debug (26692) requesting params every: 10 Sec
mihome-vacuum.0 2020-09-06 21:47:54.641 debug (26692) no answer for get_status(id:108) received, giving up
mihome-vacuum.0 2020-09-06 21:47:50.808 debug (26692) no answer for get_sound_volume(id:107) received, giving up
mihome-vacuum.0 2020-09-06 21:47:50.610 debug (26692) no answer for get_clean_summary(id:106) received, giving up
mihome-vacuum.0 2020-09-06 21:47:50.410 debug (26692) no answer for get_consumable(id:105) received, giving up
mihome-vacuum.0 2020-09-06 21:47:46.160 debug (26692) no answer for get_status(id:103) received, giving up
mihome-vacuum.0 2020-09-06 21:47:45.200 debug (26692) requesting params every: 10 Sec
mihome-vacuum.0 2020-09-06 21:47:44.638 debug (26692) no answer for get_status(id:102) received, giving up
mihome-vacuum.0 2020-09-06 21:47:40.807 debug (26692) no answer for get_sound_volume(id:101) received, giving up
mihome-vacuum.0 2020-09-06 21:47:40.608 debug (26692) no answer for get_clean_summary(id:100) received, giving up
mihome-vacuum.0 2020-09-06 21:47:40.408 debug (26692) no answer for get_consumable(id:99) received, giving up
mihome-vacuum.0 2020-09-06 21:47:39.081 info (26692) should trigger cleaning all null, but is currently active. Add to queue
Wenn ich den Sauger in homee starte, sehe ich im iobroker auch eine Aktion, aber diese kommt einfach nicht beim Sauger an…
Auch vom iobroker direkt kann ich den Sauger nicht starten.
Verstehe es nicht.
Habe schon den Sauger komplett auf Werkseinstellungen zurück gesetzt - ohne Erfolg.
Habe selbst meine Netzwerkverkabelung umgebaut in der Hoffnung, dass es was bringt. Leider auch kein Erfolg.
Hoffe, dass mir hier jemand weiter helfen kann…
